Soft client Error
Discussion in '3CX Phone System - General' started by petewatterschats, Feb 23, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    A windows softphone client can not establish connection with 3CX WEB API
    what does "Presence" mean in a 3CX context
    Attached is the error screen
  2. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    Presence is the Available/Away etc status indicators.
    Have you run the Firewall Checker and does it pass all tests?
    Allen
  3. petewatterschats
    Jan 19, 2016
    151
    The server and the client are on the private network
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    Did you provisioning the phone by welcome mail?
    Is this the only client that has this kind of issues?
  5. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    Also during the 3CX Phone System setup, what DNS option did you choose, "Split DNS" or "Internal FQDN and External FQDN"? What did you enter at that point?
    One more thing you could do is to try opening the Provisioning File you used to provision the 3CX Phone (if you didn't use one, use one) app with a text editor, and find the line towards the end of the file that starts with the tag <MyPhoneServerLocalSSLAddr>, the URL found there, if you put it into a browser internally will it show something?
  6. petewatterschats
    Jan 19, 2016
    151
    I do not remember which one I used is there a way to find out
  7. NickD_3CX
    Jun 2, 2014
    1,255
    63
    You can deduce that from the the other thing I mentioned I suppose. I would recommend checking what I previously mentioned:
    Also just to clarify when I said "...if you put it into a browser internally..." I meant on the PC running the 3CXPhone app.
