Soft Client OK- Hard client with Snom 320 KO
Discussion in 'Windows' started by sycomites, Apr 3, 2008.
  1. sycomites
    Feb 22, 2008
    12
    Hi there,
    I have successfully setup the tunnel on my laptop for a remote extension using the 3CX soft client through to the Head office 3CX system.
    I can place calls and everything works fine.
    I have an issue when I try to connect a Snom 320 phone with the 3CX soft client. I have followed the manual on 3CX web site and configure all the parameters stated but the Snom phone will not register with 3CX Phone System.
    The parameters are OK for the tunnel with the 3CX soft client as this works fine.
    Has anyone successfully configured a Snom phone through the 3CX soft client when tunneling?
    I am hoping I can get this to work as this is a great way to setup a Remote Telworker from their home with a phone.
    Axel
  2. commplete
    Feb 29, 2008
    17
    I have the same issue, but I am using the Grandstream GXP2000 phone which is given as the example phone in the manual.
    see https://www.3cx.com/docs/3cx-tunnel-session-border-controller/ - new link
    My settings seem to be correct for the tunnel as 3CX soft client works fine with a headset set.
    The PC running the 3CX soft cient has an ip address of 10.0.0.4 and the Grandstream GXP2000 10.0.0.5. I have set the Grandstream Outbound proxy to 10.0.0.4 as stated in the manual, but no joy.
    Has anybody got this configuration to work ?
    #2 commplete, Apr 8, 2008
  3. darrellchapman
    Nov 26, 2007
    268
    Just out of curiosity, are either of you running firewalls on those proxy machines? If so, try turning them both off to see what happens.
  4. commplete
    Feb 29, 2008
    17
    Hello Darrell
    Thanks for the suggestion.
    Yes, the proxy pc was running the standard XP firewall.
    Disabling the firewall does not solve the problem and the Grandstream phone still reports as 'Not Registered' and cannot make/receive calls.
    Huw
  5. sycomites
    Feb 22, 2008
    12
    Thanks for this but my proxy machine is not running Windows Firewall either.
    Any suggestion from 3CX?
    Cheers
    Axel
  6. darrellchapman
    Nov 26, 2007
    268
    When I get a chance I'll try to setup my own desk phone and workstation on a different network and attempt to proxy through the client.
  7. garethb_83
    Oct 11, 2007
    25
    Post may be a little old but I'll contribute anyway.
    Just got this working today after playing with it for half hour.
    I tested it with the new 3CX softphone as of 05/06/009 via the tunnal and everything works.
    After figuring out the new 3cx phone client hasn't got the tunneling proxy built in, only a tunnelling client, I downloaded the 3cx SIP proxy install files from 3cx.
    I configured the snom 320 with local IP: 192.168.50.20
    registra as the internal IP of the 3cx server 192.168.99.100
    outbound proxy as my workstation running the new SIP tunnel software. 192.168.50.22
    Registered first time.
    I tried to make a call but only had one way audio. From my mobile to Extension (Using VoIP gateway for incoming call)
    It seemed that the snom was receiving audio but not transmitting. To see if this was a constant issue, i made several calls resulting in the same audio loss of no transmission from snom 320.
    I tried PBX delivers audio but this didn't help.
    The last thing I changed was to enable the option Symmetrical RTP (S/RTP) in the snoms config screen and BAM! works everytime without issue.
    Maybe this is old news but just in case anyone is having issues...
    Regards
  8. Thor2008
    Mar 28, 2009
    10
    i have same problem with a GXP2000
    are there also in this ip Phone a parameter that i can set for use this phone as remote ?
    Thanks Alberto
