Soft client over VPN
Discussion in 'Windows' started by yaro, Jan 22, 2009.
  1. yaro
    Jun 11, 2008
    38
    At some times I need to work from home and I'd like to use my office extension number to answer calls the way I would when at the office.
    Is it possible to somehow configure the soft client to get this functionality?
    yaro
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    If you have a VPN in place at home you can connect in the same way you do in office.
    If you do not have a VPN you should setup the 3CX VOIP Client to use the Tunnel. The various modes you can used are explained in http://www.3cx.com/user-manual/ Updated link.
  3. rico06
    rico06 New Member
    Jan 11, 2008
    143
    or use the beta 3CX phone with integat tunnel
    I use VPN from home with client 3CX and outside the 3CX Phone cleint beta and it is perfect
