Soft Phone - Bluetooth capability
Discussion in '3CX Phone System - General' started by kp_odata, Jul 5, 2007.
  1. kp_odata
    May 7, 2007
    6
    can the soft Phone be used with a bluetooth enabled headset/mic?
    Thanks in advance
    Krishna
  2. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    sure, its not the softphone that has to support it but the operating system your using.
    Assuming you have Windows XP and a bluetooth USB adapter. you can use a bluetooth headset with any kind of software.
    Just go into the settings of the softphone and choose it as output (once all the required drivers and software is installed)
    hope this helps.
  3. ess
    ess New Member
    Jun 8, 2007
    133
    You can try the following link:
    http://www.windowsdevcenter.com/pub/a/windows/2005/07/05/bluetooth.html
    I am not sure if it will work just as it would on your cell phone (with the call end button, ringing, etc.)
    Let us know how it goes.
