Soft Phone Ignore Ring Group Calls
Discussion in 'Ideas' started by teldata1, Jul 25, 2017.
Soft Phone Ignore Ring Group Calls 5 5 1votes
5/5, 1 vote
  1. teldata1
    Aug 24, 2015
    63
    It'd be great to have a feature where the user can choose to ignore ring group calls ONLY on their smart phone, but still receive ring group calls on their deskphone
