soft phones
Discussion in '3CX Phone System - General' started by way, Jun 2, 2012.
  1. way
    way
    Feb 21, 2011
    49
    Have a soft phone that does two things at least once a week. 1. Inbound call rings and can't be answered continues to ring. Phone is frozen the only way I can stop is to force closure through Task Mgr - any simpler method?
    Phil
  2. way
    way
    Feb 21, 2011
    49
    Any advice - I have found that on several occasions when I open the soft phone that the profile has been lost and I have to set up again - any ideas why this is happening?
    Phil
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    It always helps to know the details. Whose soft phone? What operating system and type of system is the phone running installed? Any other factors that might lend a clue are also useful.
    Have you looked in the event viewer to see if any logs show something relevant?
