Softkeys not registering
Discussion in '3CX Phone System - General' started by mathias1xxX, Nov 19, 2017.
  1. mathias1xxX
    Nov 19, 2017
    on my system there is an option if they call you can select
    1 office
    2 support
    3 accounting
    when people call with a normal phone they can select everything when they call with a smartphone they can't select annything
    10,737
    278
    Are you talking about callers reaching your digital receptionist (IVR), and not being able to input their selection when calling from mobiles?
    If so, what type of trunking are you using? If it is a PSTN gateway, then there may be a volume level issue. Generally mobile phones (and most newer electronic sets) will only send a short DTMF burst no matter how long the button is held, unlike older analogue sets.
  3. mathias1xxX
    Nov 19, 2017
    yeah at the IVR and if its PSTN that the what could be the solution ? i'm kinda new to this :p i'm going to check it tomorrow
  4. leejor
    10,737
    278
    It can depend on the type of trunks you are using. Ideally, the DTMF tone is converted to a SIP message. If 3CX is relying on Audio DTMF, then there are a number of factors that can come into play, including the types of Codecs being used. DTMF does not pass properly when using many low bit-rate Codecs. The fact that some phones are able to be directed correctly, suggests that some tones do get through. You will have to provide more information on the type of trunking.
    Do you just use one provider, one trunk group?
    Did this issue just begin?
    #4 leejor, Nov 19, 2017
  5. mathias1xxX
    Nov 19, 2017
    its a new setup with 1 sip trunk of the belgium provider telenet the problem occured from the beginning
    if i call with an older iphone 4s it works correctly
    if i call with my new S8+ it doesen't register the inputs
  6. leejor
    10,737
    278
    From both phones call an extension on the PBX (not the IVR), press the buttons, how does the sound of the DTMF, from both phones compare? Is there DTMF from the S8+ ?
  7. mathias1xxX
    Nov 19, 2017
    there is DTMF on the IVR from my S8+ but he doesen't register it he just keeps saying the menu and than repetes, i'm going to try a direct call tomorrow thanks in advantage.
  8. leejor
    10,737
    278
    #8 leejor, Nov 20, 2017
