SoftPhone (3CX Phone) compatible headsets
Discussion in '3CX Phone System - General' started by bmcdevitt, Oct 9, 2014.
  1. bmcdevitt
    Feb 19, 2013
    37
    I already know most headsets with correct drivers can be set to use the microphone and the ear piece for the sound.
    I am trying to find a solution to replace needing physical phones for people on the phone all day. We want to set up our CS department to have a headset when a button is pushed on the headset it answers the call, and can end it as well. We ordered several expensive headsets however none of them were compatible with 3CX. We also asked our 3CX reseller but they only had cheap USB headsets to offer where you still needed to answer the call with moving the mouse and getting the window up etc. (We can't convince a department to have to do that instead of just picking up a physical phone)
    Does such a headset exist? This is what we tried last, it was compatible with many voip systems but not 3CX.
    http://smile.amazon.com/gp/product/B002LARYAG/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    Thanks in advance!
    -Ben
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Please see on support page : http://www.3cx.com/support/
    Some Plantronics headsets are supported with their device buttons. (Plantronics Spoke sofware required).
