Softphone answer external calls
Discussion in '3CX Phone System - General' started by nnpro, Jun 16, 2010.
  1. nnpro
    Jun 16, 2010
    Hi!
    I've a 3CX Softphone4 and a Snom300 on my desk. Both are ringing when a call comes in. All internal calls can be accepted from both: softphone or snom, everything works well. When an external call comes in also both phones are ringing but when I answer with the softphone I can't hear anything --- I need to answer with the snom... How can I solve this problem?
    Thanks for your help!
  2. carolinainnovative
    May 4, 2009
    369
    5
    Give us some more details about your setup:
    Provider/Gateway?
    Firewalls (including on your computer)? Does firewall checker pass?
    3cx Logs for one of those calls (pref. verbose/debug)?
    3cx phone's debug output?
    It sounds like a pretty typical one-way audio issue.
    NOT THAT I RECOMMEND KEEPING THIS SETTING TURNED ON - but for the sake of testing, turn on "PBX delivers audio" on your extension and try picking up the external call again...
  3. nnpro
    Jun 16, 2010
    Hi! Thanks for your fast answer... I can't believe it --> we just solved the problem 5 minutes ago:
    We reduced the Audio-Quality so it worked on both: softphone and SNOM (which is prior on an ISDN-Landline).
    Thanks and Regards
    Norbert
  4. carolinainnovative
    May 4, 2009
    369
    5
    Thats good news! Congrats!
