Softphone crashes on startup
Discussion in 'Windows' started by Luis Londono, Aug 7, 2017.
  1. Luis Londono
    Aug 7, 2017
    11
    When I try to run the application, I see nothing but in the task manager I see the process running for about 1 second and then it goes away and nothing happens. Tried reinstalling the VC++ and the app itself but no luck. Below are the logs from Appdata\Roaming. PC is running windows 7 x64 Pro.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,381
    278
    Hello @Luis Londono
    Please make sure that windows are up to date with all windows updates and .net is up to date as well.
    Also disable any antivirus software for the duration of the installation and try again
  3. Luis Londono
    Aug 7, 2017
    11
    Verified that windows is up to date, tried logging in as a different user and it starts up fine, what might be the cause of that?
