Solved Softphone Display DID number
Discussion in '3CX Phone System - General' started by Bill-in-Sydney, Oct 14, 2017.
Tags:
  1. Bill-in-Sydney
    Oct 14, 2017
    Is there any way to display the DID number that an incoming call to 3CX-PBX connected to?
    I hope the API can also provide this information, as I want to launch an application based on the phone number dialled by the called. Check the doco, but does not seem possible.
    Any chance add this into the app? Should be easy.
    Or any other idea how to do this?
    11,283
    360
    Using a DID rule, a name can be added to the caller ID to help identify.
    YiannisH_3CX likes this.
  3. Bill-in-Sydney
    Oct 14, 2017
    Thanks, This worked great, and resolved the issue.
    Suggest they put the phone number and DID on different lines.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    Glad the issue is now resolved
