Softphone license
Discussion in 'Windows' started by MaiKeLNai, Feb 18, 2011.
  1. MaiKeLNai
    Feb 17, 2011
    Hi!!
    I´d like to know if the free 3cx softphone license is opensource and I´ll be able to install it in a company
    Thanks,
    11,283
    360
    I've never seen "Open sourced" mentioned.
  3. MaiKeLNai
    Feb 17, 2011
    Thanks for reply, so do u know what kind of license the softphone have???
  4. leejor
    11,283
    360
    They have made the phone available for use, with no charge. If your company requires a legal description of what that actually entails then you should probably be contacting 3CX directly (or they may reply, in this post).
  5. frinklabs
    Feb 11, 2011
    13
    Here's the licence agreement to which you agreed when you installed the softphone:
  6. MaiKeLNai
    Feb 17, 2011
    Thank you very much for ur post, it was very helpfull!
  7. tmim
    May 13, 2012
    I can see two problems with this agreement. The first is that I'm not allowed to install it on my device or any device that doesn't have a hard drive.
    The other is that I must at all times always be making more simultaneous calls than the license lets me.
  8. active5
    Jun 28, 2011
    72
    "tmim"
    I don't think those are real relevant issues. It doesn't say hard drive only device, but magnetic or optical media, which is any current storage media, SSD, hard drives, CD-rom, etc.
    And the the usage limitations refers to the 3CX Phone system not Softphone, meaning whatever your license limitation is on the 3CX phone system, it will apply to the Softphone.
