Softphone over XP Home
Discussion in 'Windows' started by jlabuelo, Feb 10, 2011.
  1. jlabuelo
    Apr 2, 2008
    74
    Hi all
    I am considering using the Assus EEPC Box (Asus thing client) and would like to install on it the 3CX Windows phone so I can connect it to our 3CX PBX. My question is, as the requirements to work with the 3CX Windows Phone need to have Windows XP installed in the client pc, would like to know if the softphone will also work over the Assus EEPC Box which has 1 GB or RAM, 1,6 GHz of CPU and "Windows XP- Home" as OS.
    Any ideas??
    Thanks a lot.
    11,086
    325
    I've use the 3CX phone on several netbooks running XP home, no problem.
  3. jlabuelo
    Apr 2, 2008
    74
    Hey this is great, thanks for the help!!
