Softphone Provisioning
Discussion in 'Windows' started by quintergy, May 5, 2011.
  1. quintergy
    Jan 19, 2009
    I am trying to get softphones V6 to provision with V10 RC. I understand that this is supposed to work, but I have had no luck. Any thoughts?
    I am using http://192.168.111.160:5000/management/provisioning
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    Provisioning mechanism is the same as in ver 5, respectively 3CXPhoneSystem v9. The difference is that 3CXPhone ver6 "knows" how to process "extra information" added by 3CXPhoneSystem v.10 to provision BLFs.
    Also, unlike v.5, 3CXPhone ver.6 performs a "broadcast provisioning request" on local network in case when no profiles are defined or no defined profile is active.
    Bottom line, it's a matter of how you set the PBX to answer a provisioning request coming from 3CXPhone.
    Regards
    vali
  3. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Also your provisioning link is incorrect.
    try: http://192.168.111.160:5000/provisioning and it should work no problems.
