Softphones Flavors
Discussion in '3CX Phone System - General' started by cjammer, Dec 27, 2006.
  1. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    I have downloaded two different one, the X-lite and a SJ Labs. both are free, but the SJ labs seems to have a problem on my system. It wont let you make calls or get a dial tone or let other phones register after it has been in use for a while. Shut it down, reset other phone and I'm back in business.
    Any one else had that problem?
    Cjammer
  2. mbehlok
    Dec 15, 2006
    19
    I also had mixed results with SJlabs. I really like X-lite and the 3cx phone is pretty good as well.
  3. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    X-Lite
    At this point I think I would soley recommend the X-Lite phone for anyone to start with. It is simple to config and works well.
    X-Lite - 2
    SJ Labs - 0
    Cjammer
