Softphones rejected trying to call in to any ext/line
Discussion in '3CX Phone System - General' started by Anonymous, Nov 7, 2007.
  1. Anonymous
    Anonymous Guest
    When trying to use a softphone (tried with 3CX and X-Lite) connecting over the Internet I get the following where the softphone registers properly but then when trying to place a call, for example to 999 for VM or to an internal line such as 100 the call is rejected as an unknown caller. Below are the two entries - first (bottom entry) showing successful registration, second (top) showing call reject. IP addresses have been changed in this post to protect the innocent.
    Any ideas? I believe I have opened all correct firewall ports.
    Regards,
    Mike
    15:58:45.661 CallCtrl::eek:nIncomingCall [CM503008]: Call(2): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 100@67.142.86.12 tid=0206666119759524 cseq=INVITE contact=103@216.12.2.206:27726 / 2 from(wire)
    15:58:25.983 ExtnCfg::updateContact [CM504001]: Ext.103: new contact is registered. Contact(s): [sip:103@216.12.24.2:27726;rinstance=c011ce4176f869f7, sip:103@216.12.24.2:39976;rinstance=af290df7d59d6e46]
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    What build number have you installed?
  3. Anonymous
    Anonymous Guest
    version
    3CX Phone System Version4.0.3205.0
    If more appropriate I can post in the beta feedback forum
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    currently, i can suggest you to do following:
    1) setup your XLite to register at FQDN, f.e. sip.yourdomain.com. Even if it doesn't exist - just make some name. it doesn't really matter if it is resolvable or not, because:
    2) tell XLite to connect thru outbound proxy, which is real (externally accessible) IP:port mapping of your 3CX box.
    3) in the general settings/direct sip calls set SIP domain to the exactly same value as in point 1) and restart the service.
    We already fixed some bugs regarding this, so in next uploaded version it will be much easier to set up external phone. But in version you have I can not imagine another way to make it work.
  5. Anonymous
    Anonymous Guest
    Success
    That worked. Thanks for your help.
