Software 3.1 has problems in german
funktion
Hello
unfortunately none answers in the German forum
the software 3.1 does not work unfortunately in German
We're quite sure the software works in German. You are going to have to be a lot more specific to get an answer.
I have windows 2000 German ( test on XP is the same )
3cx free v3.1.2434.0 into German ( new install )
1 the German umlauts not correctly represented only as special characters
2 extention add
http://localhost:5481/user_extension_info.php in english it is working
in German
Nebenstelle hinzuf?td> (so I can read it )
and with operate has I an empty screen
if I it in English provides functioned it
with the German special characters there are however formatting problems
The 3cx alpha 4.0 has the same problem with the german characters
Getting Started - Admin
Murad88
Get 3CX - Absolutely Free!
3CX
