Solved - 3CXPhone crashing on 2.1 HTC Legend
Discussion in 'Android' started by HarpBoy, Jun 20, 2010.
  1. HarpBoy
    Jun 20, 2010
    Hi all, installed the SIP client on my Legend yesterday, and it appeared to work fine. However today, it crashes without exception after establishing a call through my Asterix PBX, either a call bound for the world or just a "feature" call (ie *60). The SIP channel remains active with my server, however. I can also use a different client and it works fine. Frustrating because this client has a great feature set.
    Any suggestions?
  2. HarpBoy
    Jun 20, 2010
    Problem solved; this is due to the bug mentioned in another post whereby setting the record buffer to other than -1 causes the program to crash. I had done so trying to troubleshoot so bad jitter.
