SOLVED: Avaya sip trunk to "pass thru" without DID's
Discussion in '3CX Phone System - General' started by fixitrod, May 15, 2012.
  1. fixitrod
    May 15, 2012
    I have an Avaya sip trunk coming to the 3cx. 3cx is version 8. I can get the calls to come in and follow the path that's set when building the sip trunk. In my case it's an unregistered extension 1000 which then sends it to the message unavailable or unregistered.
    What I would like to happen is the call to connect to the extension dialed directly from Avaya to 3cx without creating DID's for every extension. I have over 1000 DID's (max available by 3cx). I've seen this work on Cisco and Asteriks but I'm not sure what the difference was. I didn't set those up.
    I basically built a default sip trunk, entered the ip address of the Avaya server, clicked next next next...... Opened the trunk went to source id and set it to id with IP address. I also check marked the "allow outgoing sip calls" and put the local ip address as the domain (10.210.2.9) under settings>>advanced. That's all I've done so far.
    Here is a 3cx log of a call from ext 1047 (avaya) to ext 5662 (3cx)..
    Avaya Trunk is 10.201.6.7
    3cx is 10.210.2.9
    sip trunk ext is 10000
    What other information would be of help. Thank You very much for looking and trying to solve this!
    11:56:29.318 Session 6079607 of leg C:2085.1 is confirmed
    11:56:29.209 [CM503007]: Call(2085): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42
    11:56:29.209 [CM503007]: Call(2085): Device joined: sip:10.201.6.7:5060
    11:56:29.209 [MS210003] C:2085.1:Answer provided. Connection(transcoding mode[unsecure]):10.210.2.9:7336(7337)
    11:56:29.209 [MS210001] C:2085.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40722(40723)
    11:56:29.209 Remote SDP is set for legC:2085.2
    11:56:29.209 [CM503002]: Call(2085): Alerting sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42
    11:56:29.053 [CM503025]: Call(2085): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42]
    11:56:29.053 [MS210002] C:2085.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7338(7339)
    11:56:29.006 [CM503016]: Call(2085): Attempt to reach <sip:1000@10.210.2.9:5060> failed. Reason: Not Registered
    11:56:29.006 [CM503017]: Call(2085): Target is not registered: Ext:Ext.1000
    11:56:29.006 [CM503010]: Making route(s) to <sip:1000@10.210.2.9:5060>
    11:56:29.006 [MS210000] C:2085.1:Offer received. RTP connection: 10.210.2.22:16418(16419)
    11:56:29.006 Remote SDP is set for legC:2085.1
    11:56:29.006 [CM505003]: Provider:[AVAYA] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Avaya one-X Deskphone 6.0.3.8a AVAYA-SM-6.1.5.0.615006 Avaya CM/R016x.00.1.510.1] PBX contact: [sip:10000@10.210.2.9:5060]
    11:56:29.006 [CM503001]: Call(2085): Incoming call from 1047@(Ln.10000@AVAYA) to <sip:1000@10.210.2.9:5060>
    11:56:28.990 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:1000
    11:56:28.990 Looking for inbound target: called=5662; caller=1047
    11:56:28.990 [CM500002]: Info on incoming INVITE:
    INVITE sip:5662@10.210.2.9 SIP/2.0
    Via: SIP/2.0/UDP 10.201.6.7;rport=5060;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC0436016059-AP;ft=10.201.6.7~13c4
    Via: SIP/2.0/UDP 10.201.6.107:15070;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC0436016059
    Via: SIP/2.0/UDP 10.201.6.107:15070;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC1436016057
    Via: SIP/2.0/UDP 10.201.6.107:15070;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC1436016056
    Via: SIP/2.0/TLS 10.201.6.7;branch=z9hG4bK8066efdc29a7e11a99b4f494bdc00-AP;ft=4782454
    Via: SIP/2.0/TLS 10.201.6.9;branch=z9hG4bK8066efdc29a7e11a99b4f494bdc00
    Via: SIP/2.0/TLS 10.210.125.78:5061;branch=z9hG4bK201_4fb2447c-6d588663-609b5600_I2661047
    Max-Forwards: 62
    Route: <sip:10.210.2.9;lr;phase=terminating>
    Record-Route: <sip:3698c904@10.201.6.7;transport=udp;lr>
    Record-Route: <sip:10.201.6.107:15060;lr;sap=709457718*1*016asm-callprocessing.sar1795541258~1337097405084~-1419541997~1>
    Record-Route: <sip:3698c904@10.201.6.7;transport=tls;lr>
    Record-Route: <sip:10.201.6.9:5061;transport=tls;lr>
    Contact: "Business, Center"<sip:2661047@10.201.6.9:5061;transport=tls>
    To: <sip:5662@10.210.2.9>
    From: "Business, Center"<sip:1047@10.210.2.9>;tag=8066efdc29a7e11a79b4f494bdc00
    Call-ID: 8066efdc29a7e11a89b4f494bdc00
    CSeq: 1 INVITE
    Session-Expires: 1200;refresher=uac
    Min-SE: 1200
    Alert-Info: <cid:internal@mydomain.com>;avaya-cm-alert-type=internal
    Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, SUBSCRIBE, NOTIFY, REFER, INFO, PRACK, PUBLISH
    Supported: 100rel, histinfo, join, replaces, sdp-anat, timer
    User-Agent: Avaya one-X Deskphone 6.0.3.8a AVAYA-SM-6.1.5.0.615006 Avaya CM/R016x.00.1.510.1
    P-Asserted-Identity: "Business, Center" <sip:1047@10.210.2.9>
    Content-Length: 0
    P-Charging-Vector: icid-value="32149d59-4e1d-4c87-8129-4011204a016d"
    P-Location: SM;origlocname="PCO-CM";termlocname="3cxServerName"
    11:52:35.224 [CM503008]: Call(2084): Call is terminated
    11:52:29.740 Session 6075475 of leg C:2084.1 is confirmed
    11:52:29.693 [CM503007]: Call(2084): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42
    11:52:29.693 [CM503007]: Call(2084): Device joined: sip:10.201.6.7:5060
    11:52:29.693 [MS210003] C:2084.1:Answer provided. Connection(transcoding mode[unsecure]):10.210.2.9:7332(7333)
    11:52:29.693 [MS210001] C:2084.2:Answer received. RTP connection[unsecure]: 127.0.0.1:40720(40721)
    11:52:29.693 Remote SDP is set for legC:2084.2
    11:52:29.693 [CM503002]: Call(2084): Alerting sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42
    11:52:29.537 [CM503025]: Call(2084): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42]
    11:52:29.537 [MS210002] C:2084.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7334(7335)
    11:52:29.474 [CM503016]: Call(2084): Attempt to reach <sip:1000@10.210.2.9:5060> failed. Reason: Not Registered
    11:52:29.474 [CM503017]: Call(2084): Target is not registered: Ext:Ext.1000
    11:52:29.474 [CM503010]: Making route(s) to <sip:1000@10.210.2.9:5060>
    11:52:29.474 [MS210000] C:2084.1:Offer received. RTP connection: 10.210.2.21:16424(16425)
    11:52:29.474 Remote SDP is set for legC:2084.1
    11:52:29.474 [CM505003]: Provider:[AVAYA] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Avaya one-X Deskphone 6.0.3.8a AVAYA-SM-6.1.5.0.615006 Avaya CM/R016x.00.1.510.1] PBX contact: [sip:10000@10.210.2.9:5060]
    11:52:29.474 [CM503001]: Call(2084): Incoming call from 1047@(Ln.10000@AVAYA) to <sip:1000@10.210.2.9:5060>
    11:52:29.474 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:1000
    11:52:29.474 Looking for inbound target: called=5662; caller=1047
    11:52:29.474 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 10.201.6.7;rport=5060;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC0435999844-AP;ft=10.201.6.7~13c4
    Via: SIP/2.0/UDP 10.201.6.107:15070;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC0435999844
    Via: SIP/2.0/UDP 10.201.6.107:15070;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC1435999842
    Via: SIP/2.0/UDP 10.201.6.107:15070;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC1435999841
    Via: SIP/2.0/TLS 10.201.6.7;branch=z9hG4bK804ee24d29a7e115c844f494bdc00-AP;ft=4782454
    Via: SIP/2.0/TLS 10.201.6.9;branch=z9hG4bK804ee24d29a7e115c844f494bdc00
    Via: SIP/2.0/TLS 10.210.125.78:5061;branch=z9hG4bK1fa_4fb2438c22a30085-609b70be_I2661047
    Max-Forwards: 62
    Record-Route: <sip:10.201.6.107:15060;lr;sap=709457718*1*016asm-callprocessing.sar1795541258~1337097165562~-1419554176~1>
    From: "Business, Center"<sip:1047@10.210.2.9>;tag=804ee24d29a7e115a844f494bdc00
    Call-ID: 804ee24d29a7e115b844f494bdc00
    CSeq: 1 INVITE
    Min-SE: 1200
    Content-Length: 0
    P-Charging-Vector: icid-value="94494780-e92b-4ae2-9862-ad723ca8bc62"
    Max-Forwards: 62
    CSeq: 1 INVITE
    Min-SE: 1200
    Content-Length: 0
    11:52:21.334 [CM503008]: Call(2083): Call is terminated
    11:52:13.006 [CM503007]: Call(2083): Device joined: sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42
    11:52:13.006 [MS210003] C:2083.1:Answer provided. Connection(transcoding mode[unsecure]):10.210.2.9:7328(7329)
    11:52:13.006 Remote SDP is set for legC:2083.2
    11:52:12.849 [CM503025]: Call(2083): Calling Unknown:Ext.EndCall@[Dev:sip:EndCall@127.0.0.1:40600;rinstance=00d7e03f2b040f42]
    11:52:12.803 [CM503016]: Call(2083): Attempt to reach <sip:1000@10.210.2.9:5060> failed. Reason: Not Registered
    11:52:12.803 [CM503017]: Call(2083): Target is not registered: Ext:Ext.1000
    11:52:12.803 [MS210000] C:2083.1:Offer received. RTP connection: 10.210.2.22:16476(16477)
    11:52:12.803 [CM505003]: Provider:[AVAYA] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Avaya one-X Deskphone 6.0.3.8a AVAYA-SM-6.1.5.0.615006 Avaya CM/R016x.00.1.510.1] PBX contact: [sip:10000@10.210.2.9:5060]
    11:52:12.787 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:1000
    11:52:12.787 [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 10.201.6.7;rport=5060;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC0435998296-AP;ft=10.201.6.7~13c4
    Via: SIP/2.0/UDP 10.201.6.107:15070;branch=z9hG4bK0AC9066BFFFFFFFFFD601EBC1435998294
    Via: SIP/2.0/TLS 10.201.6.7;branch=z9hG4bK0e6584429a7e1138824f494bdc00-AP;ft=4782454
    Via: SIP/2.0/TLS 10.210.125.78:5061;branch=z9hG4bK1f3_4fb2437c-31a6b253-609b68fc_I2661047
    Record-Route: <sip:10.201.6.107:15060;lr;sap=709457718*1*016asm-callprocessing.sar1795541258~1337097148881~-1419555305~1>
    Call-ID: 0e6584429a7e1137824f494bdc00
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Re: Trying to get Avaya sip trunk to "pass thru" without DID
    Same problem here, Cisco Call Manager and 3cx... I created extension numbers as DID on 3cx...
  3. fixitrod
    May 15, 2012
    If I didn't have over 1000 extensions the dids would work. But I'm stranded at this point.
  4. fixitrod
    May 15, 2012
    I tried setting it up as a pstn as well and no luck.
  5. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Can you try with bridge?
  6. fixitrod
    May 15, 2012
    Solution: the vendor was sending the wrong IP address to us. The address they sent to us was our own. In the log you can see the to and from extension look like they are from the same IP. Once that was corrected a default generic sip trunk worked amazingly well with no adjustments, no inbounds adjustments...nothing, it just works.
