SOLVED: Call drops after 30 sec on hold - no hardware
Discussion in '3CX Phone System - General' started by Bob Denny, Feb 22, 2009.
  1. Bob Denny
    Bob Denny New Member
    Feb 21, 2009
    131
    I have a mystery... here's the setup:
    Bria -> CallCentric -> 3CX -> Bria
    The first Bria (a softphone by CounterPath) calls sip:foo@bar.com which is the SIP URI of the second phone (which is an extension on the 3CX switch). The call completes fine. Then the second Bria puts the call on hold, and the 3CX switch starts playing hold music, which can be heard on the first Bria. 30 sec later the call drops.
    I searched the forums here, and the existing threads talk about silence detection settings on VOIP gateways, etc. I have no hardware involved, so the only way to fix this would be with a setting on the Bria softphone or the 3CX switch. I've crossposted to the Bria forum too.
  2. Bob Denny
    Feb 21, 2009
    131
    Re: Call drops after 30 sec on hold - no hardware
    Even more strangeness with a PSTN call into my DID number:
    PSTN -> DID -> CallCentric -> 3CX -> Bria
    If the Bria puts the PSTN caller on hold no hold music can be heard and again the call drops after 30 sec on hold. In the previous scenario, at least the hold music could be heard by the caller.
    Now I have 2 questions. If you want I can post the one regarding "no hold music for PSTN -> DID" in a separate thread...
  3. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Do you use Dlink ADSL modem?
  4. Bob Denny
    Feb 21, 2009
    131
    No, no hardware at all. Hence the title 8) It's all software even the phones (the Bria softphone).
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Bob,
    try to bind the extension (which is handled by Bria) to media server (tick "PBX delivers audio"). It should help.
  6. Bob Denny
    Feb 21, 2009
    131
    Stepan --
    Thanks for the suggestion! I tried that but it didn't help. However, I just solved both problems by changing VOIP Provider, Advanced tab, Provider Details settings:
    • Supports Re-invite -> OFF
      Supports Replace -> OFF
    After these two changes, the hold music is heard by external callers coming in through CallCentric, and the 30 sec call-drop is no longer a problem.
    I must say, I am so impressed with the 3CX switch. As I get experience and eventually make it a mission-critical part of my business, I'll buy a license. You guys definitely deserve it.
  7. Bob Denny
    Feb 21, 2009
    131
    Update: I was browsing the Technical Docs at http://wiki.3cx.com/Home/technical-documentation-dash/media-server and discovered that turning off Re-Invite forces the switch into Transcode mode just like PBX Delivers Audio. I must have made a mistake when I tested your solution, I apologize.
    I don't want transcoding for every call I make to CallCentric. I need to find out why I have these problems with Supports-Reinvite turned on (and the other two turned off). Time for my network sniffer and help from CallCentric.
    Thanks again for pointing me in the right direction.
  8. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Transcode only kicks in when necessary, i.e. parties have negotiated different codecs. Otherwise we will just proxy RTP stream (i.e. receive it on media server and than send to other party without any change).
    Note, that if you want to have music on hold for endpoint that doesn't really understand re-INVITE (and Callcentric is the case as I see) - you are bound to bind to media server. Otherwise PBX is forced to issue re-INVITE.
  9. SY
    3CX Support
    Jan 26, 2007
    1,825
    Why don't you want transcoding?
  10. Bob Denny
    Feb 21, 2009
    131
    I don't want transcoding because I think it limits the call quality negotiation to the (small set) of codecs that 3CX supports. Perhaps that's wrong?
    Related question: Can I add to the set of codecs? My SIP phone (CounterPath Bria) has many more.
