[solved] Can't connect to Web-Api with 3CX Client 12.5
Discussion in 'Windows' started by Biber, Jul 28, 2015.
  1. Biber
    Jul 28, 2015
    23
    I can't connect to the web api of our 3cx-Server from Windows 3CX client 12.5.
    If I try it with the old client (12.0) it works fine, so I don't think there is a firewall, proxy or AV problem.
    The version of our server is 12.5.
    Can anybody help?
    Thanks in advance
    Biber
  2. Biber
    Jul 28, 2015
    23
    Re: Can't connect to Web-Api with Windows 3CX Client 12.5
    we solved this problem.
    A simple re-provisioning of the affected 3cx-Phone (you can do it in the phone-list) solved the Problem
    Biber
