[SOLVED] CANT make intranet calls
Discussion in '3CX Phone System - General' started by primobruno, Oct 12, 2007.
  1. primobruno
    Oct 12, 2007
    Hi ppl:
    1st i must congratulate the "3CX TEAM" for this excelent piece of software.
    CONGRATULATIONS !!! (and thanks) :wink:
    I'm sure i'll be much happier when i can make my 1st call. (hehe)
    Well, let me tell what i've done:
    I've installed 3CXPhoneSystem31.exe and 3CXPhone.exe on my portable computer.
    It runs on XP SP2 with Kaspersky (only AV, no firewall) and also disabled firewall from windows.
    I can access the server and i can register the "PhonerLite" with it.At least appears on the "Line Status".
    Here is the image from the "Server Status":
    "Image not found"
    Here is the image from the "PhonerLite":
    "Image not found"
    I've installed, on another computer the PhonerLite to test the "intranet" calls, but all i get is the error 102:Recovery on timer expiricy
    Can someone help me, please?
    Thanks in advance. :wink:
  2. primobruno
    Oct 12, 2007
    I've solved this....by REMOVING the "domain" on the PhonerLite configuration.
    Duhhhh....to me. :lol: :roll: :wink:
