Solved Client 15.5.6354.2 can't, client 15.5.3849.1 can
Discussion in 'Windows' started by jerometls, Nov 20, 2017.
  1. jerometls
    Nov 20, 2017
    Hi there,
    We have a 3cx system here on which we had update this morning (automatic update).
    The users have a message on 3cx asking for update, so most of them clicked Ok.
    After this, the client 15.5.6354.2 is no longer able to register extension.
    Previous client used was 15.5.3849.1 is still able to register and make/receive calls.
    I have warned users who have updated yet to not update so far and wanted to know if someone hare had the same issue with new version 15.5.6354.2.
    Installing v15.5 available at https://downloads.3cx.com/downloads/3CXPhoneSystem155.exe cures issue.
    Thanks,
    Jérôme
    #1 jerometls, Nov 20, 2017
