Solved: Error accessing voicemail from IVR
Eurylink
We have a 3CX v.9 SP1 Installed with language set to IT. I found that we cannot log in voicemail menu calling an external number with IVR because system didn't accept any input or number extension.
Tx
Re: Error accessing voicemail from IVR
Is it not even asking for the input OR is it asking, but not responding to your input?
It ask me only for input extension number but if we input the extension it continue to ask.... It doesn't ask for pin.
Hi, did you upgrade to SP2?
Also when you reach voice-mail and you put the extension number at the end you are putting the sign # (222#) Correct?
OR you are just putting the Extension? (222)
3CX v.9 SP2. There is no difference even if i put # after the extension number. The system continue to ask for extension number for 3 times then say "thank you" and close the call.....
Can you confirm that you can access to voicemail with v.9 SP2 ? Maybe is only my isolated problem ?
Hi, I can confirm that this works. I tested on all languages not only Italian. Can you send us your backup to [email protected], so I can check it out and replicate this in house.
Thanks and Regards
Just open the LoginVmail.vxml file - and search for this field:
<field name="ext_number_field">
<grammar>#|[0-9|*]{3-3}</grammar>
<prompt bargein="true" timeout="10s">
<!--audio src="GetPrompt.aspx?id=EMPTY" /-->
</prompt>
<filled>
and change {3-3} to {2-2} -
In your case this should be like this -
<grammar>#|[0-9|*]{2-2}</grammar>
</prompt>
<filled>
Perfect ! this solve the issue.
Tx for your help.
Getting Started - Admin
matchofficees
Get 3CX - Absolutely Free!
3CX
