feestbeestzaandam
New User
- Joined
- Jun 6, 2009
- Messages
- 27
- Reaction score
- 0
I am using 3cx 7 and i am verry pleased about it,
But i want to know if something is possible with this system.
I have 1 sip trunk (voipbuster), with that sip provider i can use more phonenumbers.
example: if u have 2 frizboxes or other sip divices i can use the same sip provider with the same login and password but send a other (extern) caller id.
Now i want to use for the 3cx system tyhe same principle.
Now i have to use 3 voipbuster acounts for 3 numbers (caller id's)
extention 1 uses vb 1
extention 2 uses vb 2
extension 3 uses vb 3
What i want is that all the xtentions can use 1 vb acount but send all 3 a other extern number.
The reason???
I have 3 butgetphone acounts and 2 pstn lines so i have 5 numbers.
I have to pay for the 2 pstn lines and budgetpone(sip) if i call to outside numbers.
Voipbuster is free and intervoip cheaper then a normal line.
So i want to call with 1 vb acount but use 3 or 5 caller id's (voipbuster accepts 5 caller id's and 2 parallel calls)
who can help me??
The reason???
who can help me??
