Solved { Solved} Looking For Security/Harding Guidelines: Remote Login Attempts
Discussion in '3CX Phone System - General' started by JCLloyd, Mar 12, 2018.
  1. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    113
    20
    Are there decent 3CX guidelines or online training related to how far I can go to harden the system? I want to block unwanted remote access attempts I am seeing on the system. I am trying NOT to lock it down to the point it is useless.
    I did find this interesting link, but it is very generic, and doesn't address firewall settings...
    https://www.3cx.com/blog/docs/how-to-react-when-3cx-phone-system-is-under-attack/
    I already locked in port 5060 to my SIP provider, but things like this keep showing up in my activity logs. I seem to have missed something very basic for phone systems:
    [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 198.23.255.226: ...
    username="c",realm="3CXPhoneSystem",nonce=" ... ",uri="sip:00441173255610@{My IP Address}"
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    11,129
    330
    From the looks of it you are getting Direct SIP call attempts, rather than attempted registrations, which is common. If you have blocked all IPs, other than your SIP provider (and perhaps a few others), then the router is allowing these through. I've seen many of these. They always seem to be trying to call UK numbers, for some reason.
    #2 leejor, Mar 12, 2018
  3. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    113
    20
    Leejor... I think I made a beginner-class policy error in the firewall. Enabling the 'deny' policy after setting it up really helps! Strange how I didn't notice that until I posted, but I should be good.
    May someone else benefit from my goof!
    accentlogic likes this.
