Solved: .NET Framework 4 doesn't work
Discussion in '3CX Phone System - General' started by YamiHoshi, Sep 6, 2010.
  1. YamiHoshi
    Sep 6, 2010
    16
    At work, I have to install XP VPS's with 3CX.
    Now my problem is, I can't seem to make it to work.
    I installed .NET Framework 4.0, but the 3CX installer says "3CX PhoneSystem cannot be installed on systems with .NET Framework version lower than 3.5".
    So this means, version 4 is lower than 3.5? ┐('~`;)┌
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Re: .NET Framework 4 doesn't work
    Hi, You still need to install 3.5 .
    So Uninstall .NET Framework from your machine, Install .Net 3.5 and then update if you want to 4.
  3. YamiHoshi
    Sep 6, 2010
    16
    >>MichaelB
    It successfully installed, using .NET Framework 3.5.
    Thanks for the quick support!
