[SOLVED]No RTP Packets were received....
Discussion in 'iOS' started by pat, Nov 7, 2011.
  1. pat
    pat
    Feb 12, 2008
    34
    Strange Problem inside LAN and Outside (with Tunnel!).
    When i want to call from iPhone App it rings at the other end, when i pickup the connection is hangup. In the log is see:
    When i want to make a call to the iPhone App, no ring, and the message: Unsupported Media Type
    all the same inside the LAN without Tunnel (same Subnet without Firewall), and also outside by Tunnel Connection.
    Calls between other Phones, also with Tunnel Connection, is working.
    Thanks for any help.
    pat
    Device Info
    Phone Model: [iPhone]
    Generation: [4G]
    Firmware Version: [4.3.3]
    Jailbreak: [YES]
    Cydia Installed: [YES]
    Issue Info
    Handset: [Phone]
    Contacts: [Local]
    Connection: [WiFi|3G]
    Server: [Internal]
  2. pat
    pat
    Feb 12, 2008
    34
    Only Codec G711 activated.
