Solved: Outgoing calls in Voicemail Menu
Discussion in '3CX Phone System - General' started by phxlad, Aug 27, 2010.
  1. phxlad
    Mar 24, 2008
    13
    Is this supported in the Free Version?
    I have enabled it in Global Options in General settings and it allows me to enter a number but the Activity log shows not action requested.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Re: Outgoing calls in Voicemail Menu
    Hi, Yes this is supported in the free version too.
    When you enter the number is the call successful?
    Also we need Verbose Logs to identify your issue, if you want you can send them directly to me - mb@3cx.com.
    Note - Enable Verbose Logs ( Setting > Advance > Verbose)
    Thanks and Regards
  3. phxlad
    Mar 24, 2008
    13
    Loaded up a soft phone and using the dial a number from the voice mail menu worked.
    I rechecked the configurations for the Polycom and the out bound proxy was not correct. Updated the settings and all is now working as documented.
    Thanks for your help in installation this release.
