Solved:Outlook - an error occured processing an inbound call
Discussion in '3CX Phone System - General' started by NickK, Sep 18, 2010.
  1. NickK
    Feb 27, 2010
    45
    Outlook gives this message when processing incoming call:
    an error occurred processing an inbound call
    an item with the same key has already been added
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    401
    Re: Outlook - an error occured processing an inbound call
    Hi, we released the new assistant with outlook CRM for 2010.
    Install this build and let us know if you can still replicate your issue.
    Thanks and Regards
  3. NickK
    Feb 27, 2010
    45
    Thank you for your help, it seems to be fixed now. It was outlook 2007
  4. idahosting
    Oct 1, 2010
    Re: Solved:Outlook - an error occured processing an inbound
    Can you please elaborate on this? I have this issue happening with many users. The users are using the most current Assistant version and Outlook 2007 with the proper plugin.
