SOLVED: Press #1 for English: How2adapt the design of ur IVR
Discussion in '3CX Phone System - General' started by dx7, Oct 18, 2010.
  1. dx7
    dx7
    Oct 7, 2010
    25
    So I was wondering how people adapt the design of their IVR to accommodate "press #1", "Press #2", "Press #3" etc... when the system of extensions is set to work with more than one digit.
    "Press #100 for English, Press #200 for X" maybe?
    Maybe there could be a feature request to include the option of dynamically changing the amount of digits?
    Or to have the option of having a "single digit IVR" on one dedicated extension?
    I'm very amazed with 3CX by the way.
  2. dx7
    dx7
    Oct 7, 2010
    25
    Re: Press #1 for English: How2adapt the design of your IVR
    Duh!
    I'm totally loosing respect for myself in the process though. I'm glad this is just a monologue with a few generously quiet witnesses!
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Re: SOLVED: Press #1 for English: How2adapt the design of ur
    Digital receptionist. You can program redirect based on 1 digit.
  4. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    You may create a VAD application to do that. There you can ask for user input and then take the decission depending on what the user has entered.
