Solved **Solved ** snom 760 provisioning failure :-(
Discussion in '3CX Phone System - General' started by mindsuk, Oct 2, 2017.
  1. mindsuk
    Sep 29, 2017
    18
    Hi all!
    It´s frustrating! I´ve got an Snom 760 phone, but I don´t get the phone running. The phone wasn't display at the System Management Console, so I tried to provision it manually.
    After I´d copy the provision link at the phone web UI, the phone boots. I see the extension at the display, but it doesn't´t register to the 3CX!?
    Please help me with it! Please have a look at my screenshots..
    I have a new Debian version of 3CX running. I tried different Snom firmware files too, but without luck!
    Greetings Tino
  2. GiannosC_3CX
    GiannosC_3CX Guest
  3. mindsuk
    Sep 29, 2017
    18
    Hi GiannosC_3CX!
    I´ve got an local 3CX system running!
    Okay, now I load the firmware snom760-SIP 8.9.3.66 on my phone. I did a hard reset, but the phone is still not displaying at the 3CX web management console "marked in Bold"! I couldn't see the phone there..
    Please help!
    By the way...is this a special 3CX firmware file? I´m asking because I couldn't change the settings url manually!? There ist a url but it´s greyed out!?
    https://xxxxxx.3cx.de:65001/rps/cfg{mac}
    #3 mindsuk, Oct 4, 2017
  4. GiannosC_3CX
    GiannosC_3CX Guest
  5. mindsuk
    Sep 29, 2017
    18
    Hi GiannosC_3CX,
    no I didn't! I don´t know how to do this via RPS..
  6. mindsuk
    Sep 29, 2017
    18
    I really don‘t know whats wrong..the phone was running well with Askozia PBX
  7. mindsuk
    Sep 29, 2017
    18
    Hi!
    Ok, now I´m a little step further. After I tried to provisioning via RPS (without luck), I could change the provisioning link in the phone webUI to the local IP Adress of my 3cx system. I login with the extension number and the voicemail PIN, the phone display has now the 3cx theme to show, but I get a new SIP identity status "25@192.168.178.111:5062: Registration failed".
    Please help!
  8. mindsuk
    Sep 29, 2017
    18
    I did a hard reset of my nom 760 again and tried it again via RPS. Now I get the message, that my Internet IP Adress has been blacklisted for 1800 sec. :(
  9. GiannosC_3CX
    GiannosC_3CX Guest
    hi mindsuk,
    I have sent you a P.M. Please check your inbox.
  10. mindsuk
    Sep 29, 2017
    18
    Dear Giannos,
    today, as I get home from work, my snom 760 is unregistered again. I tried a hardreset and rewrite the provisiion link in the web gui of the phone again. the phone boots up and did a firmwareupdate (it´s strange, because I had the latest firmware 8.9.3.66 on it at this time). After firmware install and reboot I could see, that the phone was provisioned, but it´s still not registered !?
    Could you please help?
  11. GiannosC_3CX
    GiannosC_3CX Guest
    Hi mindsuk,
    Please check if the ip phone is blacklisted on the management console and let us know.
  12. mindsuk
    Sep 29, 2017
    18
    I checked it. No, it isn´t!
  13. GiannosC_3CX
    GiannosC_3CX Guest
    I have sent you a PM.
  14. mindsuk
    Sep 29, 2017
    18
    Thanks a lot to Giannos! The problem was the port 5062 which was not included into the iptables so the iptables (firewall) drop the registration between the ip phone and the system.
