star1
- Joined
- Apr 7, 2010
- Messages
- 43
- Reaction score
- 0
We have a Patton SN 4960 connected to a US T1 circuit. The unit is working smoothly with 3CX with one exception. We're having a problem with receiving caller name. I've debugged it and we're receiving it on time from the provider. When we enable the caller-name option in the ISDN interface, 3CX correctly receives it.
The problem is that when it's enabled, we're no longer able to make outbound calls on the T1. It seems that the caller-name option is 2 way. Meaning that when enabled, it receives & transmits name presentation info. Our telco provider apparently doesn't like us sending presentation info because the call is getting disconnected. Here's some ISDN debug info from the patton.
Is there a way to only receive the info and not send. I'm thinking maybe there's a way to create a mapping table to strip caller name presentation info for calls going to ISDN, but I'm not comfortable enough with mappings.
Any advice is much appreciated. I'm including ISDN logs below of good/bad calls in case anyone's interested.
Thanks,
Eric
Good Call
23:35:18 ICC > [IF_ISDN_0] NEW CALL. Allocated Endpoint IF_ISDN_0-00a98508
23:35:18 ICC > [EP IF_ISDN_0-00a98508] do not reroute because: no endpoint with call key: YzhjODczMTBlYWVlNzE0MTJhYzQxODQyNzU0NGQwMTM.
23:35:18 ICC > [EP IF_ISDN_0-00a98508] AOC-S User << Call Setup
23:35:18 ICC > [EP IF_ISDN_0-00a98508] AOC-D User << Call Setup
23:35:18 ICC > [EP IF_ISDN_0-00a98508] AOC-E User << Call Setup
23:35:18 ICC > [EP IF_ISDN_0-00a98508] >> [080005]
SETUP (NI2 User)
[04039090A2]
Bearer capability : 3.1kHz Audio - CCITT
circuit mode - 64kBit/s - G.711 U-law
[1E028583]
Progress indicator : origination address is non-ISDN
private network serving remote user - CCITT
[6C0C008039313437353036373131]
Calling party number : 9147501212
unknown number - unknown numbering plan
presentation allowed - user provided not screened
[700C803139313734333234373030]
Called party number : 19174321313
23:35:18 ICC > [EP IF_ISDN_0-00a98508] Set state to CALL INITIATED
23:35:18 ICC > [EP IF_ISDN_0-00a98508] State: CALL INITIATED, Event: PEER CONNECTED
23:35:18 ICC > [EP IF_ISDN_0-00a98508] Hold State: IDLE, Hold Event: PEER CONNECTED
23:35:18 ICC > [IF_ISDN_0] << Message: primitive=43
23:35:18 ICC > [EP IF_ISDN_0-00a98508] << [080002]
CALL PROCEEDING (NI2 User)
[1803A98381]
Channel id : 1 - exclusive
other interface - is not d-channel - CCITT - b-channel units
23:35:18 ICC > [EP IF_ISDN_0-00a98508] State: CALL INITIATED, Event: TERMINAL PROCEEDING IND
23:35:18 ICC > [EP IF_ISDN_0-00a98508] Set state to OUTGOING PROCEEDING
23:35:22 ICC > [IF_ISDN_0] << Message: primitive=44
23:35:22 ICC > [EP IF_ISDN_0-00a98508] << [080003]
PROGRESS (NI2 User)
[1E028188]
Progress indicator : inband information available
private network serving local user - CCITT
23:35:22 ICC > [EP IF_ISDN_0-00a98508] State: OUTGOING PROCEEDING, Event: TERMINAL PROGRESS IND
23:35:22 ICC > [EP IF_ISDN_0-00a98508] State: OUTGOING PROCEEDING, Event: PEER INBAND INFO
This is what happens when we pass the caller name through when it's enabled
23:32:56 ICC > [IF_ISDN_0] NEW CALL. Allocated Endpoint IF_ISDN_0-00dce1b8
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] do not reroute because: no endpoint with call key: NTY2N2U5MzlmNzk0NTI0YjE3ZmQ3YjBlMzNkYjI2NGY.
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] AOC-S User << Call Setup
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] AOC-D User << Call Setup
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] AOC-E User << Call Setup
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] CNIP << Name Request
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] >> [080005]
SETUP (NI2 User)
[04039090A2]
[1C189FA115020101020100800D2245726963204D616E64656C22]
Facility : Invoke : invokeid: 00000001
global operation
invoke {
present = 1
local = 0
argumentnamePresentationAllowedSimple = '"JOHN DOE"'
[1E028583]
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] Set state to CALL INITIATED
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] State: CALL INITIATED, Event: PEER CONNECTED
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] Hold State: IDLE, Hold Event: PEER CONNECTED
23:32:56 ICC > [IF_ISDN_0] << Message: primitive=43
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] << [080002]
[1803A98381]
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] State: CALL INITIATED, Event: TERMINAL PROCEEDING IND
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] Set state to OUTGOING PROCEEDING
23:32:56 ICC > [IF_ISDN_0] << Message: primitive=34
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] << [080045]
DISCONNECT (NI2 User)
[080282A9]
Cause : temporary failure
public network serving local user - CCITT - Q.931
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] State: OUTGOING PROCEEDING, Event: TERMINAL DISCONNECT IND
23:32:56 ICC > [EP IF_ISDN_0-00dce1b8] Set state to DISCONNECT INDICATION
Thanks,
Eric
Good Call
SETUP (NI2 User)
[04039090A2]
[1E028583]
[1803A98381]
PROGRESS (NI2 User)
[1E028188]
SETUP (NI2 User)
[04039090A2]
global operation
invoke {
present = 1
local = 0
[1E028583]
[1803A98381]
[080282A9]
