(SOLVED)V5 Transfer error from PSTN to FXS to IP PHONE
Discussion in '3CX Phone System - General' started by AldoLinares, Dec 28, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    The problem i have right now its that when i got a call from pstn and answer it from an FXS phone and then do a transfer to GXP2000 the GXP2000 only get the music on hold the calling party just blank on the logs everything normal.
    This is very urgent because i already remove the Panasonic PBX the setup its this:
    3CX Phone System Version5.0.3762.0
    1- GXW4104 - 4FXO
    1- GXW4004 - 4FXS
    15 - GXP2000
    Please any help or clue or suggestion i will apreciate it
    Thank you.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi AldoLinares,
    Please found my V5 testing environment for your reference.
    Patton SN4960 for ISDN/PRI/T1 (PSTN)
    HT503- 1 FXO and 1 FXS
    GXP2000 (unofficial Grandstream FW 1.1.5.3)
    PSTN call ->SN4960->3CX->HT503(FXS with extension 505) answered the call from PSTN
    EXT 505 press flash key
    *87473 (Transfer the call to GXP2000 with EXT 473)
    GXP2000 can both ways communication with PSTN side.
    Since my setup just simulate with you. Just for your reference. Hope you can fixed this issue soon.
    Happy new year 2008.
  3. AldoLinares
    Nov 12, 2007
    135
    5qg4 thanks for replying
    On V3 with this setup on another client to transfer a call i just press flash then the phone number and hung up.
    Now i need to use *87 then the extension?
    Thank you
  4. AldoLinares
    Nov 12, 2007
    135
    Now its working Thank you.
