Some voicemail recordings too long
Discussion in '3CX Phone System - General' started by Stacey Richards, Jun 28, 2013.
  1. Stacey Richards
    Jun 27, 2013
    Hello Forum,
    I have noticed that some voicemails continue recording well after the caller has hung up. Is there a setting that I'm missing that allows 3CX to detect a disconnection from the caller and stop recording? Would this be something that needs to be set in the PSTN gateway. We're using a Grandstream GXW4108.
    Regards,
    Stacey.
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Yes, it would be at the gateway.
    I have had to make adjustments to some Patton devices for a client about this exact issue.
    Has to do with something about detecting when the call is over.
  3. Stacey Richards
    Jun 27, 2013
    Hi Ian,
    Thanks for your post.
    I've had a look on the Channel section of the Grandstream gateway and changed the Call Progress Tones values to those specified at http://www.3cx.com/downloads/misc/GXPblog/CountryToneSetValues.pdf.
    Here's hoping it's fixed now!
    Thanks again for your suggestion.
    Regards,
    Stacey.
