Some
Discussion in 'Ideas' started by 3t, Feb 8, 2016.
  1. 3t
    3t
    Feb 24, 2015
    It will be great to implement the following Windows functionality with 3CX Client for Windows
    - When Windows detects communications activity: "Mute all other sounds"
    And the ability to put 3CX in Busy state when you are communicating on Skype or Skype for Business.
    And the ability to choose different ring tones for: (In Exemple)
    - Internal / External Call
    - Each Ring Group his own RingTone
    Chris
