Someone has tested Patton 4552 on 3CX?
Discussion in '3CX Phone System - General' started by marcovalli, Apr 1, 2007.
  1. marcovalli
    Feb 26, 2007
    14
    Hallo,
    i'm trying the Patton 4552..... i'ts very complex and i need a configuration that work fine.
    Thank You
  2. Anonymous
    Anonymous Guest
    Never heard of it. But here is a tip for ya.
    Provide a link to an online manual and explain (much detail as possible) what you trying to do. For example VSP etc.
    For sure someone will have a crack at it.
    Henk.
  3. marcovalli
    Feb 26, 2007
    14
    PAtton 4552
    this is the linkof manual...http://www.patton.com/manuals/SCG-r320.pdf
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,875
    171
    patton is supported
    Patton is supported. There is even a configuration manual in the FAQ
    http://www.3cx.com/support/patton-smartnode.html
  5. marcovalli
    Feb 26, 2007
    14
    PAtton 4552
    Thank you; I have installed and configured it.. I have a little problem the audio output don't work ( using ISDN ) . The called don't hear the voice but the calling hear the called... ( using VOIPSTUNT audio it's OK )
    can you help me ??
    Thank in advance
