itfarmer said:Are you using a SPA9000 in combination?
From 3cx point of view every fxo port can be seen as a gateway.
Having said that your user ID will be the line ID (eg 10001) and your password is what you setup in the line management.
THat should work in theory, you might have to setup dial plans (to rout to the 3cx box).
If you point me to an admin manual for sure we can figure it out.
Henk.
itfarmer said:Hmm might work, problem is the password but if you leave that blank in 3cx it might work.
http://www.dayboro.info/3cx/Take2/3cxLineConfiguration.jp.
Use STATIC IP = this will be the IP address of the 3cx box.
SIP Settings: SIP Port = 5060 (3cx Port)
Subscriber Information: User ID = 10000 (Same as in the line configuration ID)
Use for the voice codecs G711 (either one will do).
Only problem is the password, I do not see where to enter that but leave it blank in 3cx and it might work.
My understanding is that although there are 4 lines in, it only advertises one (SPA9000 only sees it as one line). I guess you have to do the same with 3cx, also you cannot configure a SIP port per line either. So I am not sure how to go about that as yet.
If you get it going you might let us know what the log shows re incomming call eg. does it show. FXO_Port_ID1 etc. You migth be able to put the Line ID from 3cx in there I do not know without testing it. (not having a spa400 myself )
bfleishman said:itfarmer said:In My SPA400:
User ID: What does this relate to with respect to my 3CX Config
Port ID: What does this relate to with respect to my 3CX Config
Since there is no password field, I should leave blank in 3CX? Is this what you were reffering to in previous post?
In My 3CX
Internal Number: Value comes from SPA400?
External Number: Value comes from SPA400?
Authentication ID: Value comes from SPA400?
Authentication Password: Value comes from SPA400?
I appreciate all the help. Thanks again.
Brian
http://www.jaydien.com
itfarmer said:bfleishman said:itfarmer said:In My SPA400:
In My 3CX
Brian
User ID realates to the authentication ID in 3cx, you set this up when you create a new line that is connected to the gateway/provider you created.
http://www.dayboro.info/3cx/Take2/3cxLineConfiguration.jpg
Port ID is the SIP number again you configure this when you setup a gateway or provider.
FXO_Port_ID, looks like that is used as an ID aswell, put in there the same number you have in the USER ID. 10000
Ill have a closer look when I get back in the office, but this might help you on your way.
Henk.
Unfortunately though it is still not registering the PSTN lines. I have not seen any errors in the log for quite some time also. How do you manually force a registration of the PSTN lines. Restart the 3CX services?
To their credit I do not think we using the device where it originally was designed for. It was designed to provide more FXO port for the SPA9000 was it not?LINKSYS has really made this a difficult box to work with!!!!!
itfarmer said:Unfortunately though it is still not registering the PSTN lines. I have not seen any errors in the log for quite some time also. How do you manually force a registration of the PSTN lines. Restart the 3CX services?
:lol: We are pretty much on our own here I guess. Nobody has gone here before, but tha makes it fun .
Perhaps we can do something with the advanced options, but I do not know much about them (as yet). The Gateway got some intersting options all the way at the bottom Require (optionally: authorized) registration for: I have no idea what they do really, but what will happen if you select Nothing (doesn't require registration at all) would that work?
You might not be to worried about the lights going green in the line status area, as long as you can receive calls? I think we got the mapping of the user ID etc correct it is now only the authorisation to make 3cx happy.
I was thinking...... can you try to set the SPA400 up as a provider instead of a gateway? But again not sure if that will work or actually will do anything.
Have you tried to make an inbound call and see if it is "popping up" in 3cx?
But than again that should not stop us :twisted:
Question for the 3cx guys:
Can we trick 3cx in not needing a PWD etc. To be honest it is a bit "limiting" to have password requirements for gateways. Would be nice if we could do that without authentication to bind the line to the gateway that is.
Hope this helps.
Henk.
Here are the results when I call in: (Line Always Stays Red And Status Unregistered)
09:30:39.828 Endpoint::findSource Can not find source by following specs: From: 'anonymous'; To: '10000'; Rline: 'spa400'; Contact: '10000'
itfarmer said:http://www.3cx.com/forums/viewtopic.php?t=1035
Might actually shed some light on our situation . I have not read it but it looks like it is allong the lines we try to solve (based upon you error messages).
Oops should have used edit :?
carlo_isap said:Can I ask for the settings of this one? I also have a problem connecting from spa400 to 3cx as gateway.
thanks in advance
itfarmer said:Perhaps a little much to ask but I am keen to see some of your 3cX screen shots.
Especially your line management and gateway configs for those lines you use with the SPA400.
How are you log files?
Henk
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
