- Joined
- Aug 7, 2007
- Messages
- 297
- Reaction score
- 0
Ok, im going to explain everything here to see if i can get you all to understand me.
Im running 3cx on windows 2k3 server enterprise with 3 Voip Lines and 1 PSTN line (SPA3102).
2 of the VOip lines use a proxy to connect to their host and the other one is VoipStunt.
Also got a Grandstream 2000GXP, now, the thing is if i call from the ip phone i get the call to go through pretty fast, i get the ring tone right away except for when i dial through PSTN line, takes a bit longer to connect through this one. What annoys me is, when im calling from the phone connected to the SPA3102 using one of those 2 lines that connect through proxy to their host, takes me about 15seconds to hear the first ring... Its all ok on server logs so 3cx its not the problem. Something is missing on the SPA3102 configuration, already tried to change a few settings but without luck. Wonder if anyone can help me here.
Also got the Echo problem with the SPA3102 but that one i've red a few threads already and im taking care of it has we speak.
If u could help me on the Delay problem it would be nice. Thank you
