SonyEricsson Xperia Arc: No sound in speaker
Discussion in 'Android' started by jesfab, Feb 10, 2012.
  1. jesfab
    Nov 17, 2011
    I have no speaker sound in 3CXPhone for Android version 1.3.4 on my SonyEricsson Xperia Arc. Even if the other part puts the call on hold there’s no sound (no MOH).
    I use the Android together with 3CXPhone for Windows (version 6.0) and 3CX Phone System version 10 running in Windows XP SP3.
    The sound works fine in the opposite direction (i.e., from Android to Windows).
    The situation is the same wherever the call is initiated.
    The Xperia runs Android version 2.3.4.
    11,291
    361
    Do you mean the earpiece?
    Are you using this over WiFi or 3G? Have you tried it over WiFi on the same LAN as your PBX installation?
    What about when you receive a call? Any audio?
    Have you gone over the 3CX log for the call, anything show an error or problem?
  3. jesfab
    Nov 17, 2011
    Yes.
    WiFi.
    It's the same wherever I receive the call or I place the call from the Android.
    Here is the log. The Android has ext. 14.
    11:26:42.858 [CM503008]: Call(56): Call is terminated
    11:26:34.907 [CM503007]: Call(56): Device joined: sip:12@10.20.1.39:2207;line=7eb7423065d394f9
    11:26:34.907 [CM503007]: Call(56): Device joined: sip:14@192.168.1.2:46838;ob
    11:26:34.897 [CM505001]: Ext.12: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Ninja GlobalIPTel 4.8 Build 16889] PBX contact: [sip:12@10.20.1.49:5060]
    11:26:34.897 [CM503002]: Call(56): Alerting sip:12@10.20.1.39:2207;line=7eb7423065d394f9
    11:26:30.851 Currently active calls - 1: [56]
    11:26:29.339 [CM503025]: Call(56): Calling Ext:Ext.12@[Dev:sip:12@10.20.1.39:2207;line=7eb7423065d394f9]
    11:26:29.309 [CM503004]: Call(56): Route 1: Ext:Ext.12@[Dev:sip:12@10.20.1.39:2207;line=7eb7423065d394f9]
    11:26:29.309 [CM503010]: Making route(s) to <sip:12@10.20.1.49:5060>
    11:26:29.309 [CM505001]: Ext.14: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Android 1.3.4] PBX contact: [sip:14@10.20.1.49:5060]
    11:26:29.299 [CM503001]: Call(56): Incoming call from Ext.14 to <sip:12@10.20.1.49:5060>
    11:26:17.401 [CM504001]: Ext.14: new contact is registered. Contact(s): [sip:14@192.168.1.2:46838;ob/14]
    /Jesper
  4. leejor
    11,291
    361
    So IP 10.20.1.49 is that of your 3CX server, you local LAN is 10.20.XX.XX, correct?
    The IP of Ext 14 (the Android) is 192.168.1.2, with port 46838, correct?
    I'm going to assume that the Android is behind another router. If that is the case then it should be registering with the public IP of that router (and it's local port number) , not a private IP, which it is doing now.
    Check to be sure that STUN is set-up properly, on the Android, and that you are using the "I am out of the office" setting.
  5. jewel86
    Feb 27, 2012
    Other ideals ? I tried, but it's not' ok :(
  6. jesfab
    Nov 17, 2011
    Yes.
    Yes.
    I cannot register my Android on a public IP address, it requires changes in our network configuration. Unfortunately! :(
    STUN Server is set to stun3.3cx.com.
    I have tried with "I am out of office" checked and unchecked. But the result is the same.
  7. leejor
    11,291
    361
    If the Android phone continues to register using a private IP, (that is the IP that 3CX will use to try to reach the phone), then it will continue to fail.
    If you cannot make changes to your network to allow this, then it sounds like you are out of luck.
  8. jesfab
    Nov 17, 2011
    I have no problem with registering. And (as I wrote earlier) it goes fine making calls, picking up calls, put calls on hold, etc. My only problem is the missing sound in the Android's earpiece.
  9. leejor
    11,291
    361
    Sorry, I thought you were experiencing no sound of any kind. If it's just getting the sound in the earpiece, but you do get sound from some other "device" (bluetooth, speaker, etc.) then it would seem to indicate some sort of incompatibility issue between the 3CX phone App and your particular set.
