Sort Agent Extensions by Logged in Status
Discussion in 'Ideas' started by voiphorizon, Apr 12, 2018.
  1. voiphorizon
    Feb 23, 2016
    25
    5
    On the queue manager view, it would be great if there could be an option to sort agent extensions by login status.
    Otherwise, it is very difficult to find logged in agents, specially where queue size are greater than 50
    Thank you,
