Sort DIDs in Trunk
Discussion in 'Ideas' started by 0xDEADC0DE, Dec 1, 2017.
Sort DIDs in Trunk 5 5 6votes
5/5, 6 votes
  1. 0xDEADC0DE
    May 29, 2017
    8
    It's not easy to find the created DIDs in the trunk settings.
    Everywhere where I can chose a DID, I get a sorted list.
    But inside the trunk, they are sorted by creation date which
    is not good. Please sort DIDs in trunk also.
  2. 12494
    12494 Member
    Apr 16, 2010
    281
    22
    In Windows I just do Ctrl-F on the page and type in a couple digits. Faster than scrolling through a hundred DIDs.
  3. 0xDEADC0DE
    May 29, 2017
    8
    And how do you see if between the block xxx200 and xxx250 are numbers free?
    You can even create duplicate DIDs without an error.
  4. LtFrankDrebin
    Mar 17, 2018
    15
    I see this as a problem too!
    There's no sort order of the DIDs and thus no way to find contiguous blocks.
    Also having the possibility to add DIDs more than once does not make me feel comfortable.
    We have about 2000 numbers to handle so it would really be nice if this could be implemented.
  5. Phillip Horn
    Sep 1, 2017
    9
    Yeah I agree. Maybe make a checkbox for the 'default DID' and sort the rest. 600 DID's is a lot to sort through for us, and I'm sure others have many more (although many may only have 10 or 20)
