Sort order of the Phones page
Discussion in '3CX Phone System - General' started by engin411, Jan 5, 2017.
  1. engin411
    engin411 New Member
    Jul 3, 2009
    172
    3CX latest version. Every time when I load the Phones page, there is no sort order. I always have to click the EXT column header to sort by extension in order to quickly find the phone I need to work with. It never saves this, but it always resorts to the same order of phones. In my case, extension 19 is always on the top, although extension 10 should be.
    Clicking the EXT column header works to sort the phones by extension number, but this is a small irk that I wish would change. Why can't this page have a default sort order and save the sort order that I want?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Hello engin411
    i believe your post would be better served in the ideas section of the forum so that people can upvote this so it might get implemented.
