Sound problem / one way audio
Discussion in 'Windows' started by iossi01, May 2, 2011.
  1. iossi01
    May 2, 2011
    5
    Hello
    I'm a newbie in 3CX.
    I've installed yesterday the free version (V.10) intending to learn it.
    The installation works fine on a WIN-XP machine.
    I've build 2 extensions (100,101) and added a VOIP provider.
    One extension was connected by BRIA as explained. The Bria connects fine to the 3cx.
    At 3CX I've defined "outgoing rule". Till here everything is fine.
    Upon connecting a call I am unable to hear the party on the other end.
    It seems there is a mute option enabled or a span security option enabled. See attached desc.!
    Please help and advice.
    I've tried to perform Echo test (*777) and everything is fine there !
    Iossi
    11,117
    329
    Are both extensions on the same LAN as 3CX? No audio between what? Extension to extensions? One/both extensions outbound ? Audio one way, or just none at all? Did you open (forward) all necessary ports in the router that 3Cx is behind? Did you run the firewall check within 3CX?
  3. iossi01
    May 2, 2011
    5
    Hi leejor,
    On the same LAN everything works fine.
    I've checked the firewall within 3CX and everything works fine.
    The problem is that the Bria extension calls the party is unable to hear. I hear the other party ok.
    Even Echo test is not working regardless what I said previously.
    Thank you.
  4. leejor
    11,117
    329
    Bria is...a SIP application? I'm not familiar with it. You're using it from outside your LAN? That is the only SIP device that has problems? Do you have it set to make use of STUN.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If Bria and PBX are running on the same computer, then (in Bria configuration) you need to specify server location as 127.0.0.1 (not 192.168.10.14)
  6. iossi01
    May 2, 2011
    5
    Thank you for the tip. I'll try it tomorrow at my office and I'll tell you if it was a success.
    Iossi ;)
  7. iossi01
    May 2, 2011
    5
    Hi Stepan,
    Your advice was real good. Now the situation is much better.
    I have one small little problem remaining.
    I have 2 extensions (100,101). Extension 100 is connected to Bria inside the LAN and your advice solved the one way audio problem.
    The second extension (101) is connected to a SIP device outside the LAN. I've added there stun as requested.
    From ext. 101 I can call everywhere and it's OK. (this includes ext 100)
    The problem is that I cannot call 101 from 100. The call waits for a while and than the voice recorder starts... (Cause: 408 Request Timeout; internal)
    Have you any idea about that ?
    Thanks a lot,
    Iossi
