Soundstream IP 6000 - Can't Register
Discussion in '3CX Phone System - General' started by egiblockDM, Apr 23, 2013.
  1. egiblockDM
    Apr 22, 2013
    39
    I've followed the guides and all that, but can not get this SoundStation IP 6000 to register with our 3CX system. Any tricks or tips that I should know about that isn't online somewhere ?
    Phone Model SoundStation IP 6000
    Part Number 3111-15600-001 Rev:F
    UC Software Version 4.0.3.7562
    BootROM Software Version 5.0.1.10553
    0423151212|sip |4|03|Registration failed User: 4244, Error Code:480 Temporarily not available
    and i've typed in everything correct that I can see.
  2. egiblockDM
    Apr 22, 2013
    39
    I downgraded the phone to bring it closer to the guide from 3CX.
    Code:
    Part Number	 3111-15600-001 Rev. B
    MAC Address	 00:04:F2:E4:23:64
    IP Address	 10.1.2.153
    SIP Software Version	 3.3.5.0247
    BootROM Software Version	 4.5.0.0093
    here's the log file now:
    Code:
    000045.279|cmp  |*|00|Initial log entry. Current logging level 4
    000045.279|wmgr |*|00|Initial log entry. Current logging level 4
    000045.292|ssps |5|00|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=23, req=24, extra=-1, extraRep=-2, resType=3, desc=3147.
    000045.312|ssps |5|00|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=26, req=27, extra=-1, extraRep=-2, resType=3, desc=3148.
    000045.312|ssps |5|00|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=32, req=33, extra=-1, extraRep=-2, resType=3, desc=3147.
    000045.328|slog |*|00|Initial log entry. Current logging level 4
    000045.328|so   |4|00|Could not find IP address for SNTP server.
    000045.332|ssps |5|00|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=35, req=36, extra=-1, extraRep=-2, resType=3, desc=3148.
    000045.332|ssps |5|00|sspsHdiMsgProc: id=210 (SspsHdiMsgDtHAck), len=12, seq=39, req=40, extra=-1, extraRep=-2, resType=3, desc=3147.
    000045.479|app1 |*|00|Initial log entry. Current logging level 4
    000045.480|app1 |4|00|StatusBar is disabled
    000045.481|app1 |4|00|mb.main.home parameter is empty
    000045.482|mb   |*|00|Initial log entry. Current logging level 4
    000045.507|ldap |*|00|Initial log entry. Current logging level 4
    000045.507|ldap |4|00|ldap: Not Enabled
    000045.507|ldap |4|00|cDynamicData::cDynamicData:cDynamicData:Failed
    000045.977|efk  |*|00|Initial log entry. Current logging level 4
    000045.983|so   |*|00|User registration (4244 Conference Room) [0-4244]
    000118.279|sip  |4|00|Registration failed User: 4244, Error Code:480 Temporarily not available
  3. jasit
    jasit New Member
    Feb 12, 2013
    171
    did you setup the dhcp server settings? I am pretty sure I was only able to get it to provision once that was setup.
  4. cpontus
    Feb 17, 2012
    42
    I just setup one of these units using the latest firmware:
    BootROM Software Version 5.0.3.1667
    It was plug and play for me. On the 3CX side I just created the extension and put in the phone's mac address. On the DHCP side I created a reservation and added the correct Option 66 string to the record and was up and running.
    Try updating the firmware and doing a factory reset on the device. Then delete/re-add the extension in 3CX. Also make sure to check the provisioning folder on the server and clear out any MAC.cfg files for the device.
  5. cpontus
    Feb 17, 2012
    42
    Try updating the firmware and then deleting/re-adding the extension in 3CX. Also make sure to check the provisioning folder on the server and clear out any MAC.cfg files for the device.
  6. egiblockDM
    Apr 22, 2013
    39
    i downgraded the boot loader and software to the following (since my org. post)
    BootROM Software Version 4.3.0.0246
    ** information about the 3cx installaton.
    it is a remote installed 3cx system not part of our domain.
    running the multi-tennant version (this install is on tennant 2 port 6060)
    we have other phones (yealink and grandstream) that have been working fine with the system ~ these have all been auto provisioned with the option 66 from our dhcp server.
    went into the phone and formatted the system.
    phone came back up and was blank, it never picked up the correct option 66 information.
    rebooted the phone.
    booted and got the provisioning information. but when i hit the dial button i get the message "URL calling is disabled"
    changed the outbound proxy (it was blank) and the line configuraton transport to udp and rebooted the phone.
    still the same "URL calling is disabled" message.
    before the format of the file system and the manual configs, i was at least able to get a dial tone before just couldn't make any calls.
    in both tests the line never registers with the system
  7. egiblockDM
    Apr 22, 2013
    39
    i've done all that, wiped & formatted the phone again, let it auto provision from the server and it got all of the information. it never registers with the 3cx system and if i hit the dial button it says "url calling disabled"
  8. egiblockDM
    Apr 22, 2013
    39
    wiped and formatted the phone again. it auto-provisioned from the server and got all of it's settings. however it never registers with the phone system
