Source ID Problem which could not be solved
Discussion in '3CX Phone System - General' started by macher, Mar 31, 2008.
  1. macher
    Mar 31, 2008
    8
    HI,
    we have installed the software and outbound works well.
    But Inbounded just without the extensions.
    I have checked the part from the http://www.3cx.com/support/source-id-errors.html
    But this did not help because 018903642200 is the main number 018903642 plus extention 200
    WOuld I need to do this for every extention?
    This I thing wouldn´t make a sense.
    Your help is appretiated - thanks
    [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:018903642200@85.126.13.154:5060;rinstance=035e9f46a90a9e71 SIP/2.0
    Via: SIP/2.0/UDP 212.41.253.181;branch=z9hG4bK1997.80752825.0
    Via: SIP/2.0/UDP 172.29.183.11;rport=5060;branch=z9hG4bK1997.3c622557.0
    Via: SIP/2.0/UDP 172.29.183.103:5062;branch=z9hG4bK7b5cd19aa
    Max-Forwards: 69
    Record-Route: [sip:212.41.253.181;r2=on;lr=on;ftag=deb5771a5389633]
    Record-Route: [sip:172.29.183.10;r2=on;lr=on;ftag=deb5771a5389633]
    Record-Route: [sip:172.29.183.11;lr=on;ftag=deb5771a5389633]
    Contact: [sip:0676840374300@172.29.183.103:5062]
    To: [sip:018903642200@p1.voip.inode.at]
    From: [sip:0676840374300@p9.voip.inode.at];tag=deb5771a5389633
    Call-ID: db488ad8f667360b7ba87497ee569e23@p9.voip.inode.at
    CSeq: 441193280 INVITE
    Session-Expires: 600
    Supported: timer, replaces
    User-Agent: Patton SN2400 MxSF v3.2.8.45 00A0BA020B1D R3.21 2007-09-14_RFE10808 H323 SIP
    P-Preferred-Identity: [sip:0676840374300@172.29.183.103]
    Content-Length: 0
    Thanks in Advance,
    Ernst
  2. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    Add an DID number with that caller id and route it to an extension/que/group
  3. macher
    Mar 31, 2008
    8
    HI, I have tried this -
    I have added the following DID:
    DID Name: Test 200
    DID/MSN/Mask: 018903642200
    Override incoming Caller ID with DID name: Selected
    Anywhere
    Connect to Extension: 200
    And I still get the following Error Message in the Server Status
    INVITE sip:018903642200@172.29.183.103:5060;rinstance=6c1a1652e42bdc79 SIP/2.0
    Via: SIP/2.0/UDP 212.41.253.181;branch=z9hG4bK279f.ad903e17.0
    Via: SIP/2.0/UDP 172.29.183.7;rport=5060;branch=z9hG4bK279f.921fc1a2.0
    Via: SIP/2.0/UDP 172.29.183.102:5062;branch=z9hG4bK48deadcb7
    Max-Forwards: 69
    Record-Route: [sip:212.41.253.181;r2=on;lr=on;ftag=156009dabfd12b0]
    Record-Route: [sip:172.29.183.10;r2=on;lr=on;ftag=156009dabfd12b0]
    Record-Route: [sip:172.29.183.7;lr=on;ftag=156009dabfd12b0]
    Contact: [sip:06509796299@172.29.183.102:5062]
    From: [sip:06509796299@p9.voip.inode.at];tag=156009dabfd12b0
    Call-ID: 2f8f77406c739806aecd0cfa6b2bb08c@p9.voip.inode.at
    CSeq: 1468900846 INVITE
    User-Agent: Patton SN2400 MxSF v3.2.8.45 00a0ba00ac60 R3.21 2007-09-14_RFE10808 H323 SIP
    P-Preferred-Identity: [sip:06509796299@172.29.183.102]
    Content-Length: 0
    Did I fill in the fields wrong?
    Thanks,
    Ernst
  4. Powermage
    Mar 19, 2008
    103
    If u use an * as the DID and select the voip provider, what do you get then?
  5. macher
    Mar 31, 2008
    8
    Where would I use the * ?
    Could you show me how it should look like?
  6. macher
    Mar 31, 2008
    8
    I have tried it in the following way
    DID Settings
    Name 510
    DID/DDI number/mask *510*
    Override incoming Caller ID with DID name checked
    VOIP Provider: Inode
    Connect to Extension: 510
    Still the same problem
    11:29:23.609 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:018903642510@172.29.183.103:5060;rinstance=8f12b17e4b3db109 SIP/2.0
    Via: SIP/2.0/UDP 212.41.253.181;branch=z9hG4bKfb58.2ec0d162.0
    Via: SIP/2.0/UDP 172.29.183.15;rport=5060;branch=z9hG4bKfb58.28ff9ab2.0
    Via: SIP/2.0/UDP 172.29.183.103:5062;branch=z9hG4bK7bb16401b
    Max-Forwards: 69
    Record-Route: [sip:212.41.253.181;r2=on;lr=on;ftag=40f06e1165d00fc]
    Record-Route: [sip:172.29.183.10;r2=on;lr=on;ftag=40f06e1165d00fc]
    Record-Route: [sip:172.29.183.15;lr=on;ftag=40f06e1165d00fc]
    Contact: [sip:0676840374203@172.29.183.103:5062]
    To: [sip:018903642510@p1.voip.inode.at]
    From: [sip:0676840374203@p9.voip.inode.at];tag=40f06e1165d00fc
    Call-ID: a899bb498b0b700fea31f87e976e762c@p9.voip.inode.at
    CSeq: 1716034216 INVITE
    P-Preferred-Identity: [sip:0676840374203@172.29.183.103]
    Content-Length: 0
    11:29:23.609 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 018903642510@172.29.183.103:5060 tid=fb58.2ec0d162.0 cseq=INVITE contact=0676840374203@172.29.183.103:5062 / 1716034216 from(wire)
  7. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Open Source identification section for Patton gateway and set following:
    SIP Field | Value | Custom Value
    Request Line URI : Host part | Custom Field | 172.29.183.103:5060
  8. macher
    Mar 31, 2008
    8
    I have asked the provider to do so - but they did tell me they can´t because all of their customers are on the same patton box and so it could be a problem for the others.
    Any other Idea - I would like to stick with 3cx and not go back to asterisk - because I like the way the system looks like
    But I need to make it working
    best regards,
    Ernst
  9. archie
    3CX Support
    Aug 18, 2006
    1,299
    Sorry, do you have administrator's rights for you 3CX PBX box or not? I was speaking about settings of 3CX box. That Patton is not in your posession? Is it on some VoIP provider's site?
  10. macher
    Mar 31, 2008
    8
    our configurations is as follow
    we have a telecom provider named Inode and we have there the Telenode TITAN Package which works with SIP Protokol.
    On our Side we have a PC with the 3CX Software which we did configure using the base settings for the Generic VOIP Provider.
    The provider sends us the calls directly over VOIP with the SIP Protokol to our 3CX Telefon system.
    We do not have any Patton Box inbetween.
    And the connections works because we can call out.
    But unfortunatly not in!
    Thanks,
    Ernst
  11. archie
    3CX Support
    Aug 18, 2006
    1,299
    Than open "Edit VOIP Provider" page for your provider in 3CX Management console and in section Source identification apply the changes I've mentioned above
  12. macher
    Mar 31, 2008
    8
    Thanks - it works!!!
    The only question now still is how can I adress the extensions.
    Every call which comes in goes to the routed inbound extension.
    Chears,
    Ernst
  13. h2009
    h2009 Member
    Mar 15, 2008
    447
    Sorry can you clarify what you want the incoming call to do please. Thanks.
  14. macher
    Mar 31, 2008
    8
    Good morning!
    Yes of course.
    We have 7 extensions for our phones and one fax line.
    This extension are Numbered from 200 to 206.
    We would like that our customers can directly call trough to the needed person.
    And if someone calls the headnumber it should ring at just one extension.
    i.e. if someone calls 01 890 4236 or 01 890 4236 he should come to extension 200
    or if someone calls 01 890 4236 205 or 01 890 4236 203 he should come to the called person.
    or if he calls 01 890 4236 150 he should be connected to the telefax machine.
    So people should be able to call trough.
    The SIP line incorporates the requested extension
    like
    INVITE sip:018903642200@172.29.183.103:5060;rinstance=035e9f46a90a9e71 SIP/2.0
    or
    Thanks,
    Ernst
  15. FITEC
    Sep 15, 2008
    19
    noticed that 0 is usually appended when someone calls the headnumber (without extension) - try to set SIP-ID 0 at the receptionist's extension
    check if the SIP-ID at the extension is set to 205, 203 or 150
  16. mickp
    Jun 9, 2008
    72
    Um. I don't think sip id is what you want to be looking at. Sip id is for internet calls with user@your.domain.name style calls afaik.
    Mick.
  17. mickp
    Jun 9, 2008
    72
    If I understand your request correctly, you have a working sip trunk and just need to configure some did (direct in-dial) numbers. My appologies if I'm missing the point and there's some other issue. Review the instructions http://www.3cx.com/manual/3CXPhoneSystemManual6/phone-system47.html and see how you go.
    Mick.
  18. FITEC
    Sep 15, 2008
    19
    you're absolutely right, Mick, The SIP-ID is used for internet calls but in this scenario it seems that the sip-provider uses a different field for the DIDs. will check if it's related to Source identification section (http://www.3cx.com/forums/source-id-problem-which-could-not-be-solved-4819.html#p38255) and let you know.
    DID does not work in this scenario - but in any case it's related to the SIP-provider because it works with a different one :x
