SP1 Yealink templates - DND %NULL%?
Discussion in '3CX Phone System - General' started by giwm, Aug 14, 2017.
  1. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    Are the Yealink T4 templates supposed to now be %NULL% for all the DND on/off_codes? They used to be:
    Code:
    features.dnd.on_code = %%param::DIALCODEPROFILE%%2
    features.dnd.off_code = %%param::DIALCODEPROFILE%%0
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    432
    67
    Yes this is correct, part of the way CSTA works instead of the older CTI method. The phone no longer has to dial a code to switch on/off.
  3. giwm
    giwm New Member
    Sep 27, 2016
    236
    41
    Thanks!
