SP3: "Added Stop processing of logs, vmail and recordings if HDD available size is < 500MB"
Discussion in '3CX Phone System - General' started by dab, Feb 9, 2018.
  1. dab
    dab
    Nov 1, 2009
    67
    This new feature is verry dangerous! Why not stopping PBX-functionality if Diskspace is going below a certain limit? For customers with regulatory necessary call-recording (banking, security, etc), 3cx is no longer a possible market-player.
    Can this be disabled by settings?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    Hello dab,
    I think you need to see it further then this.
    If you would be an emergency call centre, this would be a better solution for the customer to have no connection at all? Further, the admin will get a warning and can act directly upon the information. I assume when you are burdened with such regularities, you monitor your system for disc space outside 3CX own reporting, as when the disc would be 0 3cx would still run but for sure not calls will be recorded anymore. This way at least the OS is accessible to be managed or a disc can be extend.
