SP3 Myphone integration: No pickup button
Discussion in '3CX Phone System - General' started by pstulac, Sep 19, 2011.
  1. pstulac
    Jul 8, 2011
    21
    have installed SP3 and have the latest 3CXphone and Myphone but don't get the PICK UP button, only transfer, send to vmail, and reject when a call comes in. Is there something else I need to do?
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, you need to have option use 3CXPhone specified in the Settings Tab.
    In this case new Notification Tab Control is displayed on incoming calls to your extension.
  3. pstulac
    Jul 8, 2011
    21
    Got ya... under dialing select Launch 3CX phone.... at some point I would suggest possibly just having a check box and calling it "Integrate with 3CX phone" or something like that, having it under Dialing for this aspect isn't necessarily user friendly.
    Thanks for the info much appreciated.
