SP6 and Demo License
Discussion in '3CX Phone System - General' started by Felixcat, Feb 29, 2012.
  1. Felixcat
    Sep 16, 2011
    12
    I'm just a home user of 3cx and my system will never be used in a commercial company, I'd like to upgrade to SP6 to keep things up to date but I'm concerned about the license I have which is the familiar demo code ending in EIV4. Will the system still work with this code after upgrading to SP6 or will it stop working in the future perhaps? I don't expect to be able to use 3cx for free forever but would like to know when to start saving for a license!
  2. misstake2012
    May 23, 2011
    40
    It will be work with demo key but you have to reactivate licence
  3. se@svendsgade82.dk
    Jan 26, 2011
    Hi ...
    Just tried to activate former used v10 demo key - but is now revoked.
    How to obtain a new demo key ?
  4. leejor
    10,360
    226
    Re-submit your information, as if you were going to download a new version. You should receive the new code in an email.
    http://www.3cx.com/phone-system/download-phone-system.html
    Update...
    Which I did, as I had been holding off SP6. In the email it hadn't changed from what I currently have , and it ends EIV4, as you mentioned. I can only assume that you either wrote it down incorrectly, or you are using a one for an eye, or zero for an oh, or vice versa.
